Показано с 1 по 10 из 25
Тема: Immersion Tx/Rx EzUHF 8-ch 433MHz
    Передатчики Immersion EzUHF 433MHz
    Состояние: б/у в рабочем состоянии
    Цена:
    передатчики - 800 грн
    приёмник - ПРОДАНО
    JR модуль - ПРОДАНО
    тел: 050-5903666
    Причина продажи: в настоящее время используем другую систему связи, эти комплектующие лежат без пользы
    Характеристики передатчика:
    • Reliable FHSS Link (Frequency Hopping, Spread Spectrum)
    • 433MHz/70cm Ham band operation
    • GFSK modulation
    • 600mW (~28dBm) output power
    • Direct head-tracker input, adding head-tracker compatibility to most radios
    • Power switch, ability to boost power when at long range
    • Standard SMA antenna connector, compatibility with 70cm antennas
    • Flexible buffered, AC-coupled, PPM input, ensures compatibility with 3.3V ~ 9.6V PPM levels
    • Standard USB port (Mini-A) for firmware upgrades, and system configuration
    • Single push-button learning of failsafe positions
    • Binding function, which allows binding Single Tx->Rx, Multi Tx->Rx, and Single Tx->Multi Rx
    • Works with 8 channel and 4 channel EzUHF receivers
    • Power sourced directly from the R/C Transmitter (Futaba style), or optional DC power jack
    • Built in receiver for future expansion
    • Custom extruded brushed aluminum enclosure
    Specs:
    Power Requirements:
    9~12V DC 250 mA @ 12V in 600mW mode, 85mA @ 12V in 200mW mode
    Dimensions: 85x74x23mm
    Weight: 118g
    Характеристики приёмника:
    • -112dBm Sensitivity
    • Bi-directional ready * (contains onboard transmitter)
    • Diversity Antenna configuration
    • Ceramic filtered inputs, eliminates nearby high-power video Tx interference
    • Mikrokopter mode, emits PPM on a chosen channel
    • Vehicle mode, couples two chosen channels (ideal for coupling steering servos on monster trucks)
    • USB Connection for easy firmware upgrades, and advanced configuration
    • EzLink connection to a EzOSD, providing in-flight display, and telemetry down-linked parameters:
    -RSSI Ant. 1, Ant 2
    -Frequency Error
    -SNR for each freq. bin
    -Link Quality
    • Standard SMA antenna connectors, compatibility with standard 433/70cm band antennas
    • 8 standard servo connectors
    • Failsafe, preset by button on the EzUHF transmitter
    Specs:
    Power Requirements: 4.8~6V, 35mA (Rx mode), 95mA (Tx mode)
    Dimensions: 70x28x18mm
    Weight: 19g
    Актуально
    Актуально
    есть один комплект передатчик-приёмник (б/у) и несколько передатчиков (новые и б/у)
    актуально
    Актуально
    Цена:
    передатчики б/у - 800 грн
    приёмник б/у - 600 грн б/у
    JR модуль б/у - 800 грн
    актуально
    актуально
    актуально
    актуально
  1. ПРОДАМ: ЛРС Immersion
    от Ser19 в разделе БАРАХОЛКА. Аппаратура
    Последнее сообщение: 02.01.2016, 20:52
  2. Immersion 600mW 5.8GHz A/V Transmitter
    от magicm3n в разделе БАРАХОЛКА. FPV камеры, телеметрия
    Последнее сообщение: 07.11.2011, 12:31
