Сервы BMS-706 Low Profile High Speed Servo 4.6kg / .13sec / 26g
http://www.hobbyking.com/hobbyking/s...13sec_26g.html
It was designed for F3A high performance of low profile, better precision movement and low electric impedance, the low profile servo is a great choice to move your retract gear in the realistic manner that you want it to.
This servo comes with JR/Hitec S Connector also known as a "Universal Connector". Even thought this servo comes with JR/Hitec S Connectors, this servo is electrically compatible with Futaba receivers.
1. Carbon nylon gear
2. curve gear with smooth.
3. Double M9.6 ball bearing (si-oil)
4. 3 pole strong torque of motor with low signal affect and success get CE certification.
5. Rubber fitting case for waterproof
6. Same with Futaba 25 tooth spline
7. Heavy duty servo case
Weight: 26g / 0.92oz
Dimensions: 42 x 21.5 x 22 mm / 1.65 x 0.85 x 0.87 inch
Torque At 4.8V: 4.6kg/cm , 65 oz/in
Speed At 4.8V: 0.13 sec / 60° at no load
Состояние новые не использованые
есть 10 штуки
цена 13,5 ЮСД / шт
тел 068 83 36 36 3
