Флайбарлесс система для апгрейда Align 700 вертолета (нитро или електро)
Включает в себя комплект из "головы" и електрониrи Align 3G
Новая, нелетанная, в коробке
[attachment=155456:hn7093_1__40365.jpg][attachment=155459:hn7093_4__78328.jpg][attachment=155457:hn7093_2__51653.jpg][attachment=155458:hn7093_3__45199.jpg][attachment=155460:hn7093_5__39751.jpg]
Актуальные фото
[attachment=155461:IMG_9636_новый размер.JPG][attachment=155462:IMG_9639_новый размер.JPG][attachment=155463:IMG_9642_новый размер.JPG][attachment=155464:IMG_9643_новый размер.JPG]
Other Details
Operating Voltage:
DC 4.5V ~ 8.4V
Current Consumption::
< 80mA @ 4.8V
Flip and Roll rate detection speed::
±300 degrees/sec
Rudder rate detection speed::
±500 degrees/sec
Sensor resolution::
12 bit
Operating temperature::
-20℃ ~ 65℃
Operating humidity::
0% ~ 95%
Control box::
42 x 26.5 x 14.5mm
Sensor::
22.3 x 21.7 x 14mm
Weight::
Control box: 16g, Sensor: 9g, Total: 25g
Product Description
Benefits:
· Agile 3D performance is done through a 3-axis electronic gyroscopic flybarless system that digitally simulate mechanical flybar system,
· Uses Silicon Micro Machine (SMM) sensors for superior stability,
· 12 bit processors ensures higher resolution for superior precision and control,
· Software upgradeable through USB, PC interface adapter (sold separately),
· Simple 5 steps setup process with 2 sensitivity adjustments. No external devices required. Rudder setup is identical to GP780 gyro, minimizing learning curve,
· Increase 3D power output,
· Prolong both power and flight through efficiency,
· Combination of gyroscopic sensors and advance control detection program provides superior aerobatic stability than other flybarless system on the market,
· Suitable for all CCPM and mechanical mixing system,
· Compatible with helicopter of all sizes such as T-Rex from 250 to 700,
· Innovative Align Pitch Gauge to aid and to facilitate pitch adjustments,
· High frame rate signal output for faster and more precise servo response,
· Operate between 4.5V to 8.4V, compatible with high voltage servos,
· Smaller footprint, lighter weight, minimalists and reliable design.
Accessories:
· Screw bag x 1
· Linkage rod A x 2
· Linkage ball A x 2
· Head Stopper x 1
· Mixing base assembly x 1
· Pitch Gauge x 1
· Sensor mounting foam x 2
· Signal extension wire 100mm x 1
· Signal extension wire 220mm x 1
· F servo horns x 3
· J servo horns x 3
Includes
Silver main rotor head set x 1
Flybarless control unit x 1
Flybarless sensor x 1
390$ http://www.helihobby...3-open-box.html
380$ http://grandrc.com/p...31&reviews_id=9
380$ http://www.cermark.c...er-HN7093.html#
Отдам за 150$ - это цена более чем в 2.5 раза!!! меньше забугорной
или поменяю на что-нить (смотрите ниже)
Покупалось год назад "про запас" вот и лежит без дела
Менибек для проверки - 10 дней
(Moneyback - возврат денег покупателю, в случае если в товаре обнаруживается какой-то дефект, повреждения, некомплект и т.д.)
Отправлю по Украине Автолюксом, Новой Почтой или Интаймом (мне удобнее всего - Новой Почтой)
5% - мой добровольный взнос в фонд развития сайта
Интересен обмен (возможны доплаты в любую сторону) на: батареи 6S 4000-6000, вертолетно-самолетную электронику-механику и т.д. и т.п. в (в частности запчасти на алайн 700 - рама, балка и т.д.)
Короче предлагайте что-нить интересное
050 836-41-01 или в личку
Олег
